Rattling/tapping noise
98Viperblue
This has just started happening today. When I accelerate hard I get some loud tapping and or ratting like noise. I don't really feel any power loss or hesitation but just a pretty loud rattle above 3k. I have no idea what it could be. It also does it while stopped in neutral just revving above 3k as well. I have a video I will try to post it up soon.
mstg98
I have something similar going on as well. Im cheap and have been running 87oct and thought maybe it was some valve clatter? I went up to mid grade and it seem to lesson the noise significantly. I dont have enough know how to diagnose it myself, going to have to take mine to someone Mine only happens on hard acceleration too doesn't start till I'm almost WOT. Let me know if you find a fix!
98Viperblue
Same here. It seems to be on the driver side as well. I only have 93k on the car so it kinda worries me I hope it's nothing serious
mstg98
I just hit 157k :) if your anything like me, I cant stand to hear any kind of rattle or clatter, not even change haha. Planning on getting this looked at with this year's Tax rebate. I miss my highway Pulls :(
twovalveterror
Dayton, Ohio
yep, pop your valve cover off and check the lifters (lash adjusters). I really hope that's what it is, for you and your wallets sake.
JRad405
Central NJ
^Now you're getting me worried. I have that same sound when I get on the gas. Like some chains rattling. But only while I'm driving if I rev while in neutral or park nothing happens. So for me I'm ruling out the lash adjuster or whatever the thing is.
mstg98
Interesting that 3 of us so far have this problem Nothing when I rev either I forgot to mention. Hoping its a easy/ cheap fix.
MadStang
Escondido, Ca
If your car drives fine without any misses, surging, or hestitation then it might be a lifter that bled down.
yup had that happen on mine. if you let it get bad enough the cam follower will fall out of its seat. mine we're incredibly loose and you could hear the valves were not opening and closing all the way, the note sounded like a dull "thump thump thump"
MadStang
Escondido, Ca
taking the valve covers off is easy, especially on the driver side, just pop the cover of and feel the tension on the cam followers. if any feel like they could be taken out right then and there, you have a trashed lash adjuster.
JRad405
Central NJ
Probably a job when it's warmer. I know this may be a stupid question, but do I need to drain the oil? I've never done this. I'm sure its not hard probably a new gasket some gasket sealer but I'm not sure about the oil part.
vermilion
maryland
manually turn your throttle at idle in neutral about 3k. listen with a stethoscope or long straight screw driver. in the mean time i'd check your pulleys. doesnt sound like valve train noise.
twovalveterror
Dayton, Ohio
a video closer to the engine would be better, all I heard was exhaust. lol. for everyone that got worried, there are a ton of things a "tapping/rattling" noise could be. checking lash adjusters only takes a couple minutes so it's an easy thing to rule out in the diagnostic process, as well as a common problem. what vermilion recommended would help a ton. a mechanics stethoscope is best, but I've used a screwdriver before too.
I've also had what I believe to be a rod bearing go out, that never really affected driving it, but made a hell of a noise (similar to what you described) starting at 2k onward. I will tear that engine apart this winter for confirmation of this, but I hope your problem is solved by then!
JRad405
Central NJ
That video definitely doesn't sound like mine. I don't get noise unless I'm actually goosing it on the road. If I rev alone in my driveway, I hear nothing.
I'm thinking mines a loose screw somewhere.
MadStang
Escondido, Ca
No you do not need to change the oil, you don't even need a new gasket unless you REALLY want to change it.
98Viperblue
Ill be sure to get another video. I think it might have smoehting to do with the pullies because now when it is damp outside i am getting a slight squeal noise.
TheRainman
Mobile, AL
My car makes the same noise when merging onto the interstate. I run cheap gas, I figured that was the reason...
