Cat rattle ?????
Brickermaxwell
Lincoln NE
My 2004 GT has this rattle at about 1500-2000 RPM with medium load. It sounds almost like a loose heat shield but I feel like that would be much more noticeable. I already had the driver side rear cat go bad and throw code, but I used O2 sensor spacer to get the code out. Could it be the inside of the cat making this noise? It's hard to tell.
Terrorist 5.0
Hard to tell without a video so we could hear the sound.
A rattle under load is typically a good indicator for detonation.
that is what mine sounded like when it went bad, there was also small solid pieces come out of the exhaust after a while.
Terrorist 5.0
A failing/plugged cat sometimes gives off a rotten egg smell when accelerating hard. Happened to me in my old LS400 I had a couple years back. If you are hearing this rattle along with the egg smell, then a new cat/cats are probably your best bet.
