Rear end specs "NEED HELP QUICK"
JDwhite98gt
So I was refered by another stang owner to a mechanic who can rebuild my rear. I have experienced his work through my friend and he seems legit...older guy, has built a few 33 Ford show cars and has a bad a*s Vette and a twin turbo big block chevy truck. Anyway he asked me to get info on the specs for the 8.8 rear like what backlash should be set to and pinion depth...I think I said that right, I posess no knowledge on gears and setting them up. Any one know where I can get that info?
HeavyRightFoot
This should be all he needs. If I am missing something let me know and I will try to find it.
Description mm Inch
Available Pinion Gear Shims in Steps of: 0.0254 mm (0.001 inch)
224 mm (8.8 inch) and 191 mm (7.5 inch) 0.254-0.965 0.010-0.038
Backlash Between RIng Gear and Pinion Teeth 0.203-0.381 0.008-0.015
Differential Pinion Gear Thrust Washer Thickness 0.762-0.812 0.030-0.032
Differential Side Gear Thrust Washer Thickness 0.762-0.812 0.030-0.032
Maximum Axle Shaft End Play 0.762 0.030
Maximum Backlash Variation Between Teeth 0.1016 0.004
Maximum Differential Case Runout 0.076 0.003
Maximum Radial Runout of Companion Flange in Assembly 0.25 TIR 0.010 TIR
Maximum Runout of Backface of Ring Gear 0.010 0.004
Nominal Pinion Locating Shim 0.762 0.030
