rebuilding my rear end
blackice
NOTE this isn't a discussion of what gears are better for what application
I am installing a set of FRPP 3.73s in my 8.8... I am buying them from americanmuscle.com. Question is, I want to rebuild my LSD while im at it. They sell a rebuild kit for $124.99 with carbon fiber discs, shims and everything else. you can view it here: http://www.americanmuscle.com/ford-88-traclok-kit.html Is this worth it? Are there any other suggestions on something better for a bit more money OR somewhere else i can get this kit for cheaper?
badass98svt
well, i went witha termi diff which has the cf disks, but its 31 spline, so you'd need to upgrade the axles. well worth the $240 shipped! When was the last time you heard a termi blow a diff?
wayne94mustang
There's still only 3 fibers on each side, I like to add a fiber to each clutch pack for a total of 8 fibers. Then you reshim the packs and your good for a long time.
94Snake
Valdosta, GA
yeah that setup is just fine for a street car. they can live under some slick abuse too, not for too long, but depending on how often you race it's worth the money.
B
blackice
i see. well my car has some mild modifications and i am planning on keeping it on the street with a few weekends at great lakes dragaway for fun.
badass98svt
What tires do you use at the strip and how much power do you make at the wheels?
B
blackice
right now stock crap tires. i will be getting 10.5" wide nittos in the back soon. and my only mods are bigger thottle body, full exhaust, subframe connectors, a/c and smog delete, advanced timing ... so my numbers arent far from stock
slo1
I got my carbon fiber track loc kit from summit for 107 maby try them may save a few dollars
badass98svt
Keep in mind the labor $$$ fpr refreshing your diff, compared to just buying a new one.
Win
Kennesaw, Ga
I paid 250 to have my FRPP 3.73 put in and have my 28 spline trac lock rebuilt with the carbon disc. You will be just fine. If your worried about it just get some Hardened 28 spline.
LAFENATU
I have seen numerous 8.8 mustang rears with nothing more than 28 spline hardened axles run 10's all day. The stock differential can take a lot of abuse.
