Recent video since I got the Cobra running again.
Venom351R
Maine
Took this short video after I got the car running again and after a test drive. Currently I have to replace the upper radiator hose and re tighten the header bolts. Other then that it seems to be running pretty well. I'm having the dyno shop finish the exhaust for me b/c the catback system does not quite fit b/c of the custom headers and the modified Prochamber. So this month it will be tuned and sound a quieter over all.
http://youtu.be/UWwwHlFMWiQ
Venom351R
Venom351R
Maine
Yes it did, had been almost a year and a half since it had run.
Just took it out for test drive #2 and everything went well. Still really under powered but the tune will fix that. It idles really well and no more coolant leak. Not sure where it came from before but good thing I took it for another drive before changing out the gasket. Water temp is steady at 180 and oil PSI is steady at 50
Venom351R
Venom351R
Maine
haha thanks.
If I did the caculation correctly my compression should be about 9:7 range. Not really sure what to expect power wise. 400+ would be nice but I really dont know if it will have a hard time making that or blow right past it.
