Rockers
sn951992
sounds like metal on metal under my valve cover passager side. , can any one help me out with this just paid for new clutch an pacesetter long tube install was 2k now I can’t even drive the car the noise is so loud
are you sure it isn't an exhaust leak with the new headers? It is not uncommon to need to retorque the bolts holding them in after a few heat cycles. Otherwise I am confused how you added long tubes and now hear the rockers more.....
sn951992
sn951992
No they were tapping before the long tubes got put on now it’s just way worse of a sound already 2k into the new clutch has spin tech 9000 with x pipe
i put that engine together a while back and its still like that
but the engine runs fine nothing has changed on mine
is it more the Bottum or top end making noise
sn951992
sn951992
Top passenger side valve cover
sn951992
sn951992
Yeah my oil pump sensor goes low at low idle below 1,000 rpm anything higher runs fine ?!?!
sn951992
sn951992
I got a cobra upper an lower intake off another 95 i mite as well put that on if I have to tear this thing apart
