running issues
gt96stang
Car recently has had some issues..
Lost odometer and trip... and has had battery issues..
I lost the speedo, and the car sounds different coming down while in gear... and sometimes it just randomly dies while I am coming to a stop and I loose all power...
Just put a new battery in it last night because I couldn't get the old one to jump and it started up just fine and the alt. had 14v at idle.. until this morning I had the same issues.. It died as I came to a stop to turn right..
xander0561
Is it throwing a code at all? Have you had the comp read? And as far as the speedo not working, Sounds like a blown fuse. The same thing happened to my car. It's one of the fuses in the panel under the dash. Just look in the owners manual. That's all I can think of for now. Sry man.
gt96stang
gt96stang
no codes.. Cleaned the MAF, and I'm thinking it's either the IAC or TPS sensors... It seems to rev down too quickly and die..
gt96stang
gt96stang
cleaned the IAC last night and still the same issues.. No blown fuses to fix my speedo either..
gt96stang
gt96stang
No haven't had much time to really mess with it..
Put a new IAC in her and it seems as if it doesn't let it die although it gets very close..
karrarararararar said:
it could be a vacuum leak
PCV leak or faulty valve? just thinking... Id buy from Frod new PCV valve, sJegs a PCV filter, go to the auto parts store and buy some rubber hose, and replace your entire PCV system from the valve covers to the intake, and filter it while your at it...
