seat bolts
This last weekend while installing my new seats and getting everything together I was surprised to find out the rear bolts on the drivers side have been stripped. I know I didn't do it and it was probably the shop that did the air ride(got under there running lines) and just over tightened it but anyway, need to fix it. With all the crap I have behind the seats, and with the air ride I figure it will be easier for me to just run some bolts throuth the holes and tighten them up on the bottom with a nut/washer. Any idea what rating bolts I should get at a minimum? Wasn't sure if I needed something crazy or not....
ProKiller
PA
i would get some stainless so the heads don't rust under the floor. otherwise some grade 8's.
carbuff
Its a nut welded on the floor board if i remember right.. Is that stripped
Yeah, its a nut welded to the floor. I had this problem with my fox and it was just the bolt that was stripped. A new bolt made it fine.
I guess it is. My bolts had got all gummed up with my sound damping material after a few times in/out of it, the threads were just caked with the black tar/rubber material so I thought it would help to clean it out. Got the majority of it off with some brake cleaner and now they will not tighten down, just keep turning.
MustangChris
Aurora, CO
go to your local fastenal.
get the highest grade bolt (probably a 12) that you can. tell them it will see weather and needs to be corrosion resistant.
Jerry santos
