Should I supercharge my car?
Lee12609
yes, the kit thats rated at 290hp is a basic kit that re-uses stock injectors and MAF etc, no tuning basically.
to add to what blown98gt has said, to get 350 through your auto you will most likely also need a smaller pulley (8-10psi), or PI intake/cams......
its just VERY hard to say what each car will make because every dyno is different, every car is different, altitude, etc all plays a HUGE role in power.
i'd do EVERYTHING listed by blown98gt and you should be VERY pleased no matter what the dyno shows.
JUST DO IT!!!!!!!!!!
SBSVT
i dont want to screw with the cams and stuff though i just want to do the other stuff. could i still hit around the 325-350 range
Lee12609
yes, its possible, but without you'd probably be in the 280-320 range on a good tune and 8-10psi at best.
why are you so dead set on getting a certain power level??? every dyno is different so if your "buddy" has 350 on this dyno and you get on that dyno and get 390 you could both still be very close in actual power. dont get hung up on dyno numbers, they are for "bragging only", mod the car and enjoy it!
SBSVT
im not set on 350 and thats it i just want that range and i want it on a budget and without having to tear the motor apart and i dont want to end up blowing something to crap and then having to rebuild it and at 350 i feel im by far in tha safe zone
Lee12609
so then whats the problem???
my car 96 gt auto, my goal 300whp (i prefer not to be disappointed) probably wont even be put on a dyno but its possible. my setup, most of these parts i have, a couple are in the mail, and some will be ordered in the next week or so.
vortech v2 sq S-trim tuner kit (basic non intercooled kit)
42lb injectors
lightning MAF
255lph fuel pump
sniper special forces
AEM wideband
this setup cost me just at $2000, maybe $2400 with the wideband..... will it get me 300whp, who knows but for $2000ish even if i'm short by 20-30whp i'll still be VERY happy.
i also have a low mileage PI engine sitting here just incase something happens but i see no reason to need it (it was bought before i even got this car and will be built eventually). and i'm also an ase certified mechanic so doing my own work isnt an issue and knowing what i'm doing makes me alot more comfortable doing it than the average person who might be intimidated.
my suggestion would be this, if you want to play you have to pay. you want to give the majority of the new cars a run for their money for cheap but not worry about breaking something, this just isnt going to happen.
cheap, fast, reliable PICK 2......
SBSVT
another draw back im having though is im going to have a forced induction v8 that wont be much better than the n/a 2011 v6 stang if it is even making those numbers. i guess my main issue is having something thats forced induction and it not being half way beastly. im afraid of with only 300hp that a turbo ricer will hand my balls to me and then ill look real stupid having an american muscle v8 monster and just got my doors blown of by some kid with a turbo charged weed wacker under his hood
blown98gt
so like i said before, just make it a 400 hp car, with a good tune the block will handle it with no problem what so ever
SBSVT
alright so i guess what i have learned from this post is that i need to do the non intercooled vortech, injectors, fuel pump, a good tune, pi cams, and pi intake and then i should be laying down some power and objects in mirror will be loosing. does this sound about right? if my car makes it to the 350hp range then is that good and powerful/fast? sorry for so many questions ive just never driven anything as fast as my 97 mustang gt so anything faster than it is a whole new world to me. plus im new to the forced induction stuff
Lee12609
Considering you have about 175 horsepower now you should have an idea of how fast 350 horsepower will be.
blown98gt
if you are going to do pi cams might as well do a full pi swap.. it's almost pointless to do npi heads and pi cams you'd get a lot more out of a full pi swap because it will bump up the compression but when you do that and throw boost on it you need a good tuner or else you can get detonation with the blower
Lee12609
you are crazy, PI cam swap is only a couple hour job with basic hand tools, a PI head/cam swap is about a weekend and requires re-timing, who wants to do all that when in the end it will only gain another 10-20whp on a 350whp car??? i'd MUCH rather keep the NPI heads and stock compression especially with a NON intercooled boosted motor. 1-2psi of boost is going to make ALOT more power than the compression gained from the headswap at a lower boost level.
Midnight2V
Honestly if you want 350HP, then just get a set of trick flows heads/pi intake and cams. Do it at the same time and you will go from around 185 at the wheels to north of 320 at the wheels......thats around 380 flywheel. A set of heads is $1900, a pi intake can be had for $100, trick flows specific stage 2 cams for these heads is $480. Throw in the install/tune and you are at around $3500. You will also get better fuel mileage and more rpm capability. $3500 is about what a bare bones supercharger uninstalled will cost and the trick flows will make more power. Also you won't have to worry about the stress on the rotating assembly so you won't need a built bottom end. And if the power bug bites again, the supercharger is still an option, but will make even more power at less boost when you do put it on.
blown98gt
first off, totally not true about most of what you have said. Yes a procharger unit will cost more, but a vortech unit can be purchased for under 2k easy. I see them on mustang forums all the time and everyone else on here will agree that they are cheaper and there is no reason to pay anyone to install a supercharger because anyone with general mech knowledge can install a blower it's not something that requires a degree in rocket science. Also procharger/vortech will email you install directions or they can be downloaded online. Also the requirement for the heads and cam combo that you'd need to hit 350 hp would require a bump in compression which requires a tune and a higher fuel oct. Soooo in the end you're still out the same IF NOT MORE money than a supercharger would cost and you are stuck at a set hp.. you can't just upgrade because NA cams won't work with a s/c so thats even more money to change that out later down the road if he decides he wants more power. And how can you say that a h/c setup will make more power than a supercharger that is just retarded, because you can't do anything to h/c once there on that is about it, a s/c you just change a pulley is.. OOO MORE POWER! Another thing people get confused about is that once you put a power adder on your car that your gas mileage goes to the shitter which is a total lie, i can drive around all day and not see any boost. I might have lost a few mpg but you're going to lose mpg with any car that you want to make faster. I know tons of people who are running s/c on stock blocks making 400 and over hp and they haven't had any issues out of a stock bottom end. It's about getting a good tune and not being stupid. 350hp with a s/c on a stock block will NOT cause the bottom end to just blow. A good tune and a s/c at 350hp on a stock block will last for a long time. So, in end i'm not trying to bash you, or be an a$$ even if that is how it sounds i promise i'm not in any way. I just hate it when people make comments like yours and don't know what they are talking about. I've done a full PI swap with ported PI heads and i've built 4 blocks and the last one i built for boost and have a s/c so i'm not just bs'n here. In the end what it all comes down to is budget. Whatever you can afford to do that is what you should research hard and then make your own decision. Me personally and i'm sure that a lot of people will agree here, go with a vortech unit, find a good tuner that is close and email him to find out what pulley since you need to hit your desired hp.
Vortech unit [non intercooled], 42lb injectors, in-tank pump, tuner that is basically all that you will need, and every one of those things any person with a set of standard tools.. screwdriver, flat head, socket it, and a drill can do the entire install by their self. Again if it was me i'd go with the s/c because later down the road if you decide you want more and want to go with a built block then you already have a good base build block... but do what you can afford and research into all your options then make the one that you thing will be the best.
Lee12609
thanks, i didnt want to open that can of worms but i been thinking it since that was posted.
the debate of N/A or P/A will be forever fought, but you CANNOT tell me dollar for dollar building N/A is the better choice, sorry thats just wrong.
the trick flow heads are what $2500 alone, a vortech kit, supporting mods, and full tune are about the same price. sure add cams to the trick flow kit and you'll see descent power, but add cams to a supercharged 2v and the gains will be doubled.
i think *personal opinion* theres 3 types of builds: natural aspiration, forced induction, and bolt on.... bolt on and natural aspiration i put in different categories because i'm talking built N/A, not bolt ons.
figure out what power level you want, your mechanical ability, and budget, and you should EASILY see which build you should do.
blown98gt
i agree lee, and hands down 9 times out of 10 a na build or bolt on build will require the same if not more mechanical ability. I mean a supercharger consist of some very easy steps and there isn't a whole lot of piping to deal with on a non intercooled kit the only thing that really requires some mech ability is just the oil line which is a simple drill and tap job.. (vortech kit) but all in all the debate will forever go on between n/a and p/a with mpg and price.
SBSVT
Thanks everyone thats a lot of info and I think I know what I want to do now. As far as the vortech goes I think i'll probly go with a new one or one with very low usage. I'll also do the supporting mods. As fas as the PI cams go, how long would it take to do the entire PI cam and intake install? I want to get everything at once and do the entire project in one weekend if possible. Project consisting of the vortech, injectors, fuel pump, MAF, cams and intake. I aventually want to put some 3.73s or 3.55s in the ass. which ones would be better with my desired setup and for about 50% highway and 50% city driving?
Midnight2V
Yeah, that was my first post on this website, but don't mistake me for a noob. Blown98GT, I have been working on these engines (4.6/5.4 2V/4V) for over 12 years, your PI swap and four built motors isn't even a blip on the radar, no disrespect. Every thing I said was correct, just don't take it out of context.
The price on trick flow's heads and cams I gave is straight out of SUMMIT Racing's catalog....they happen to own Trick Flow FYI.
I never said you lose mpg with a blower. I said you gain MPG by changing to the Trick Flow heads, I have Fox Lake ported SVO's and when I was NA I was getting 32mpg highway through a five speed and 3.27's. When I first put my Paxton on I went to 27mpg because i richened up and went real conservative. Now I get 30mpg through a D&D viper spec with 4.10's and a paxton on a 2.75" blower pulley. While my SVO's flow slightly better than stock Trick Flows, you will definitely see a nice gain in MPG due to the increase in compression and the reduced pumping losses. Gas prices are going north of $3 again. You may get a decent return on your investment eventually. A well tuned trick flow setup will get probably at least 28mpg, what do you think a stock NPI with a blower will get?
When I said $3500 for a bare bones blower I was speaking of new base kits, not a tuner kit. Obviously a used system will be less, but a used blower has a history that you have no clue of except what the seller decides to tell you - buyer beware. As far as making more power, sure you can add a bigger pulley and make more boost, goes without saying. But I was speaking of the stock kits the blower companies have, and all of the non-intercooled NPI kits will be 6-8 psi unless you order a different pulley. At 6-8 psi, those stock kits for a NPI system will give you, wait for it....... OOOO! 290-310 rwhp. Thats less than the OP would get with the setup I recommended. If he wants to dial up the boost on that setup, new tune, more fuel components....more money. Remember the OP is stock NPI. As for being stuck at 350hp with the H/C/I setup, as I said, add a supercharger if you want more power than that. If he did it in reverse and wanted to eventually make more power than a pulley could provide (450 rwhp on stock NPI is pushing it), he would have to uninstall everything to build the upper motor at that point. Kind of a bit of a waste don't you think?
As for the built shortblock, its insurance. Stock rods and pistons are great at stock power and rpm's under normal conditions. The rods under ideal conditions will hold up for some decent power. But what happens with a bad tank of gas, a NA setup will run like crap. You get into boost at high RPM in FI setup with bad gas.....good luck. Do you need it at 350hp levels, probably no. Will you wish you had gotten one when something bad happens?......This isn't a cheap hobby and you better be prepared and willing to pony up to get things done right the first time, or fix them when they go wrong.
As to the compression bump needing a tune and higher octane, yeah that's true. But with these cars you can screw up the tune by changing the air intake with a CAI...so what's your point? I included the need for a tune in my original post. You should re-do your tune ANYTIME you do something SIGNIFICANT to change airflow or combustion characteristics. On a FI setup, you should be running high octane anyway and you HAVE to get a tune, although the manufactures usually supply a canned tune.
As for cams, just about all performance NA cams will add even more power on a FI motor. As long as you don't overdo it on valve overlap so you don't blow part of your charge out the exhaust you will see gains. I have Comp 270's and have had them NA and now FI. The idea that you can't use an NA cam on a FI setup is silly. You definitely reach a point of diminishing returns when you get really radical with the overlap, but the stage 2 trick flow cam is nowhere near and will still be a power contributor going from NA to FI.
As for people being able to do an install, the idea that your regular joe who wants a faster car having "general mechanical knowledge" is a stretch. I watch NCIS, that doesn't mean I should moonlight as a forensic investigator. You would be surprised just how many people with performance cars couldn't change a throttlebody without screwing it up with or without instructions, let alone installing a blower and an in-tank pump. You wouldn't believe some of the screwed up systems I have seen. Who is to say that that the OP wouldn't consider it a poor use of his time to do the install himself during his free time vice paying a shop to do it and stand behind their work (I'm not talking about a warranty, but if they screw something up they usually like to protect their reputation). Most shops these days charge a flat rate for a blower install plus tune. BTW, in just about all cases, if you order your parts from a shop and then have them install and tune your car, they will almost always give you a deal on some part of the project. You may have to ask, but there you go. Even if the OP installed the supercharger system correctly, going with a manufactures canned tune will definitely cost you MPG. Most canned tunes are VERY conservative. So, eventually, to the dyno they will go and they will charge you full price for sure.
I never said that that NA was a better performace to dollar ratio. The original poster asked how to get to 350hp. I simply am trying to give him a different perspective. The combination I recommended is less than the price of a new bare supercharger kit + install and will give better MPG and power than the base kit.
Personally, I like both NA and FI modifications, and a combination of modifications from both camps gives even more power.
Lee12609
like i said, pick your poison.
350whp via boost without bolt ons and tuning or 320ish MAYBE with a full topend rebuild and FULL bolt ons, i still see no advantage to N/A if you arent racing a class that limits you to N/A regardless of budget........
to each his own, my opinion would probably differ if i wasnt a boost junky though.
