I’d be interested in that! What would you charge?how big of a deal is this for you to do now? I ask because I am planning on buying a laser cutter sometime and it could cut this out of some rubber gasket material easy.
Gotcha! I’ll get some butyl tape at HD tomorrow for $6.99!well I would have to get the laser first and its in the planning stages. It will happen the question is when(I am looking into financing options at the moment). Something quick/easy like that I would feel bad charging a few bucks for each but it is a $7k machine I am dreaming of making it on....
Has to be. The weatherstripping is in tact.PM sent.
Are you sure it's coming from the spoiler?
I’ll try the paper towel trick. Don’t have an inner tube.Tape a paper towel up under the bottom and do your spray test.
I had another thought for gasket material, do you have an old bicycle inner tube? If so cut a gasket out of that.
putting a layer of vasaline on the seal and then closing it and then opening it up to inspect could tell you where it is in contact and where it isn't. I would still bet on the spoiler gasket myself. Check at your local autoparts store and you might be able to buy a small sheet of gasket material to cut your own or go to walmarnt and buy a cheap innertube.
