Ya my fuel pump whines to hell and back. I have a vert and no backseat or seat delete if that matters. Maybe its not the stock pump, but you can hear thing pretty good all the time. With the turn signal on you can hear it whining to the beat of the signal. When you press the brake @ stop you can hear the pump tone change. If you press all the window down all the way you can hear the pump tone change till you let go of the window button.Steven said:Hear the fuel pump? I hardly if ever hear my factory ones. My holly blue pump in the fastback makes enough noise that it wakes up the dead. Loud as hell.
Twista said:And i like the idea of the spring loaded fuel connectors. Mine are only held on with plastic clips which i guess how the 94-95 are put together.
DFG_Pimpin said:Twista said:And i like the idea of the spring loaded fuel connectors. Mine are only held on with plastic clips which i guess how the 94-95 are put together.
you'll like them right up until you have to pull them off... Spring lock connectors suck d*ck most of the times to take off.
