Brian95SVT
Your motor looks insanely nice. Did you powder coat everything? I hope if I ever have the money to build a motor fully, it will be this clean.
KzooMuscle said:Forged internals? I mean, I can see the obvious, but I was curious of the specs.
96_SVT_Cobra said:sxynerd said:So my car wont idle..........or even start. Have spark on some but not on others. Looks like it's the custom fit wires. Time to spend more money... Converting to COP's as we speak.
you may want to look into a KB boost-a-spark, just a suggestion if you dont already have one. i know it made a difference in mine.
sxynerd said:96_SVT_Cobra said:sxynerd said:So my car wont idle..........or even start. Have spark on some but not on others. Looks like it's the custom fit wires. Time to spend more money... Converting to COP's as we speak.
My issues were with the wires I used. I switched to COP's now and have no issues. BAS, is a band-aide to a larger problem if you seen a difference with it.
96_SVT_Cobra said:sxynerd said:96_SVT_Cobra said:sxynerd said:So my car wont idle..........or even start. Have spark on some but not on others. Looks like it's the custom fit wires. Time to spend more money... Converting to COP's as we speak.
i was mentioning that for higher rpms since you were already doing a COP conversion. it made a difference after boost hit 3psi and from then on it is on max setting. it helped in the upper rpms a lot by straightening the line on the dyno and prevents spark blowout in the upper part of the band when you will have full boost.
