Something really weird happing in the motor 1995 5.0
Mario7820
Hey everyone I have the 95 5.0 and its doing something really weird OK so i always let my car warm up to normal temp and then after driving it about 15-20 min it bogs really bad when i even push the gas pedal a little bit just bogs and will not get up to speed but when stopped idels perfect! Any ideas anyone..
Mario7820
thats exactly what i thought but i took it off and it was really clean i always clean the K&N anything else you can think of??
2slo95fiveoh
Lawrence, Kansas
i would agree with the distributor issue. I would think if it was a fuel issue that it would happen all the time, not as the car
warmed up. Electrical components (coils, distributors etc...) fail most often when warmed up, and wet. The Distributor on my
beater car started going out, after running for about 10 mins, replaced that and no issues.
Yellow94gt
Check the dizzy... also, check the o2 sensors, and agree on replacing the fuel filter, even if it's not the problem.
snakebit95
My vote is for the fuel filter. Had too many problems with my car when the filter would get some miles on it. Gas stations are pretty pitiful about keeping their tanks clean and properly filtering the gas. I still remember the last time I dropped the tank to swap the fuel pump and seen all of the trash floating around in the tank along with what was stuck on the pump sock. No other way for it to get in there besides gas stations.
Mario7820
Thanks for all the help everyone i just ordered a new dizzy.. Also a fuel filter ill let you guys know if those solver the problem... Again thank you!!!
wytstang
So it only runs like crap while under a load? Has it shut off on you or just no power? If it doesn't shut off on you I would say the PIP is fine, when a PIP is going bad it will shut off during idle/load.
95 svt cobra
My PIP is going bad. But i would say that since its only when the car is warm that its a sensor r something electrical. If it was fuel related it would be doing it at all times. Sometimes with K&N filters that oil gets put on too much and dings up the MAF. Clean it anyways to be safe.
Steven
SC
If I can drive to summerville from west ashley on a bad distributor thats not only going out but siezing up, I would figure his pip is going bad. My car idled fine but as soon as you increased rpm's it was like 2-3 dead cylinders. Random misfires, things like that. Picked up a new reman cardone from auto supply on sam ritt when I worked in mt. p and it worked great.
