Steeda Adjustable Rear Sway Bar Installed!!! *Pics*
SRT Handz
about a week ago i did my install for my Steeda Adjustable Rear sway bar. Since then i have spent alot of time in the canyons new my home testing out the new bar and getting the adjustment set. The bar made a very nice difference. Its very hard to get the rear end out now. Its grips hard in the rear. Teamed with the Cobra Rear Bar (Which is the same thickness as the Eibach or Steeda HD Bars) it give great stability. I dont think i will ever have to change the settings on the bar because i tune my suspension on a canyon road which is pretty much very close to the way the turner are at the track usually go to (Street of Willow at Willow Springs Raceway)
I am signed up for a Trackday end of February and a Auto-X event mid February....should be fun to see how the bar works out.
rgs
looks like it's not that hard of an install. about how long did it take you??
and where did ya buy it from? im lookin to do some more suspension stuff once i get my car back.
SRT Handz
It was an easy but pain to install. I had to drill holes in the frames which was difficult because holding a heavy drill, on your back, in a weird position, wears you out. You also need a second set of hands to hold the bar us.
Cost around $120 fro StangSuspension.
rgs
anyway you could get a little bit closer up pic of how the endlinks attach to the frame or whatever it is there???
SRT Handz
its excatly how it looks. It just mounts to the frame rail where it starts to curve over for the axle
black_96gt
I love your car. :thumb:
+1 for adjustable lower arms. It looks like that bar will clear a diff girdle. There was an add on bar like that on my car when I bought it, but I had to heat and bend it to clear my cover. It eventually cracked and I tossed it. Are those stock upper arms still?
voidfinger
very nice. I didn't know that the cobra and steeda hd and eibach rear bars were the same.... so now i know a cheap way to go :) +1 that bar looks cool. I'm not to sure but would it get in the way of a torque arm bar and panhard bar set up?
Magic
Some time zone
Handz, now that you've had this bar on your car for some time already....Whats your feedback on this adjustable sway bar? Im considering adding one of these to my car...
Thanks!
vermilion
maryland
im adding mine tomorrow. i done some other drive line toys :coolsmiley: .. after this mod im going for a new k-member and more front susp. toys. im hooked on suspension now.
Paul
If you're going to get an adjustable bar, get the Maximum Motorsports one.
SRT Handz
Thanks!
i hate to say i am 100% satisfied with the Bar. Works Great and makes the rear end nice and stable. I was able to fine tune out any unwanted oversteer for a great neutral set-up.
Paul
You also think having two rear swaybars is a great idea, so I'm not too concerned with your opinion.
SRT Handz
....because it is a good idea.....
