OK guys I also would like to replace the 2 fuel lines that run to the the fuel rails. One of Mt fittings broke on me. Figured might as well do it right. Haven't had any luck finding a already made kit for our cars. Found plenty for a fox. What's the easiest way to replace them? Sent from my SAMSUNG-SGH-I317 using Tapatalk
I have a black/blue set of fuel lines that I am getting ready to swap out for no other reason then because I want them all black. Been on the car for around 8k miles... PM me if your interested.
get the matching fittings and have them made at a hose shop. I had 2 made up for me cost was 20 for the hoses and 5 for the fittings at the salvage yard.
not that I know of. Any chance anyone knows which of the fittings the smaller fuel rail fit in? I have two fittings the same size for some reason to plug into the rail, which of course will not work. Any chance anyone knows which on the smaller of the two is? Anyone looking to buy one of the larger of the two, its black/chrome fitting from russel
641300 adapter for 1/4 hard line to an fitting 640860 adapter for 5/16 hard line to an fitting 640870 adapter for return line factory rail 640900 adapter for pressure side factory rail 373030 90 degree one end and straight on other 375030 45 degree one end and straight on other Fittings were blue anodized Russell. The 640860 came from jegs everything else from summit. Reason being the part number that summit tells you to use..doesn't fit. So you have to use the 640860 from jegs. The lines were fragola premade. Everything worked great on mine
