stereo question
rebelstang
I have a 1995 Mustang 3.8v6 ,wanting to install new stereo. How man/y wiring clips should I have, and what do i need to hook it up to the factory wiring harness? Does mine have the Mach 460 system, have bought harness connector for 73'-00' #FD021 will it work or what do i need to get it to work? Greatly appreciate comments or answers.
CanaryGT
Phoenix
I show how to integrate a deck into the mach system on page 2 of my cardomain page, ride# 2395420. Take a look at it and let me know what questions you have.
Now, Thats not my car, its Scott's (or ttocs).
R
rebelstang
nevermind found it,went to Autozone and bought adapter #70-5510 $19.99. It looks exactly like yours. Don't know if it will work though, but will try. What do you think?
CanaryGT
Phoenix
Give it a shot. And if it works cool... If not then well we will be here to help!
R
rebelstang
your way, which speaker wires go to which individual output wire? My radio only has 2 outputs. It is a dual plain radio w/ usb/sd/ipod jack. And I only have 2 factory wire clips.
R
rebelstang
I just have the rectangular grey clip which includes main power wires and small square black clip with 8 smaller wires
you need a 70-1770 or fdo2b hrns then and the install will be easy. REturn the other and they should have it, it is an old style standard ford radio hrns.
Yer messin with me quotin me like that yeller.... Took me a second or two...
you will not be using the rca outputs on your deck unless you are adding an aftermarket amp, you have no factory amps.
R
rebelstang
well I hooked up the harness I got, but nothing worked so I got new speakers and will bypass the entire factory system since speakers could be blown anyways.
is there a box under teh deck that is octagonally shapped with a bunch of holes in it? just for kicks hook up the remote turn on from the deck(blue/ or blue/white) to the amp turn on in the factory hrns(blue).
R
rebelstang
yes I did that . ok here is what I did I found a harness out of a junkyard, just the 2 clips power clip and speaker clip, but still don't have the RCA to speaker wire intigration clip.can I make my own harness by taking the RCA jacks and intigrating them into speaker wires if so , can you show me how to wire it because I cant tell which speaker wire goes to which Rca cable .I do have sound and sounds pretty good,but still have no bass. will deeply appreciate if could get some info thanx
R
rebelstang
speaker outputs are used ,wired to rectangular black clip ,all i have left to hook up is thhe Rca jacks, how do you wire the rca's into speaker wires beings there is 2 wires inside of each pin on rca's?
