STOPING thINGS
Demolisher
wrong with my car sometimes when im driving my car is sttuering like its boggin than when i floor it it goes away no any reason y?
G
GREG@SN95
Guest
its misfiring... could be a whole bunch of things...
timing
maf
plugs
wires
distributor cap / rotor (if Applicable)
running wrong octane fuel
my bet is a timing issue... if the weather has been changing ya may need to swap or clean the cap n rotor
ryclef331
holy shit...are you drunk?
97blackgt
maybe the TPS sensor is worn is one spot, so when you punch it that would explain why it goes away, or it could be a misfire. Hook a scan tool up and youll know in a heartbeat. Good luck
Hicks
Have you changed ur plugs???
I think that would probly be the easiest thing to check for first....
+ it can cause your car to run crappy
Then again im 17 and im ignorant so... n hoo
Hicks
haha mean green... sigh... you got all my post and +1k more :( veteran here arnt ya?
MeanGrn Gt
Post count doesnt matter its just a number. I have been around since may of last year when i got the beauty
97blackgt
If it were the spark plugs it would most likly skip when he steps on the gas petal, and is under a load. right?
trav_19
its not throwing any codes??? is there a poping sound when this happens?? does it do it mainly after start up? give more info
ryclef331
MeanGrn Gt said:
wow... basically it could be almost anything. start with ignition
Meangrn is right. You're entirely too vague. It could be a number of things. everyone here is really shooting in the dark.
Demolisher
nah its cool i figirued it out , it was my timing.... moved it back to 10 and it fixed it...
95KBGT
:rollinglaugh: :rollinglaugh: :rollinglaugh:
Rnorth71
