pretty sure the KB is rebuildable like most.I was going to go with a Kennebell supercharger but all the ones I can find for my year are used and I'd prefer something brand new so procharger kit it is
With the proper clutch, transmissionForced induction is cool and all. Kinda of expensive. Researching the money spent for a different engine platform might reveal a better option.
Them gen3 coyotes are really pumping out power. The trailer queen coyote stock drag racers are running consistent :098 quarters now. Some have pulled :096 all while at the class rules set min weight. Which i do believe is a little over 3000lb. A street mustang set up really good for straight line performance wouldnt have any problems producing 10sec quarter mile times.
Just an idea
Most likely but I haven't been able to find anything for it as it was discontinued years ago. I also looked at the vortech system but I'm definitely leaning more towards the prochargerpretty sure the KB is rebuildable like most.
I am currently checking the status on kenny bell making some for 94 95I was going to go with a Kennebell supercharger but all the ones I can find for my year are used and I'd prefer something brand new so procharger kit it is
They dont currently have the partspretty sure the KB is rebuildable like most.
How do you like the Vortech V3?I wanted to go with the procharger myself, but after I did the scottrod engine panels I wasn't sure there would be enough room between the supercharger and the panels, and then I came across a great deal on the vortech V3. $2500 for a kit that was brand new, the guy only took the box apart enough to oogle the supercharger itself before putting it back and then wrecking the car before he installed it.
Yeah not a huge fan of the 4.6 motor that's why I got a 94 with the 5.0 and yeah tuning is the biggest thing when it comes to making safe/reliable powerTomorrow as you read this I will be starting up a brand new 347 w/ all scat H beam internals and custom 8.5 CP pistons. built on a 96 explorer block and heads and a B303 cam. ( not the best but ??) it's a single on 3 turbo w/ a small turbo. if it does not run out of air I suspect it to make 800hp.
As long as I tune safe it should be OK.
My personnel daily driver is detuned to be safe at around 690-700 hp. its made 765 on pump 93. so yeah its not so hard.
I once did a stroked 4.6 on a 2004 that was Procharged and made 420 rwhp. I was not impressed. But?????
Good news was it made great power, bad news was the stock trans did not like the new power. I just swapped a T56 and now finally started to open it up and no complaints now.How do you like the Vortech V3?
Weighing in, I like my V2/SQ on my '95. I'm at 10PSI with 400RWHP (corrected). When... err.... if I keep my foot out of it, the only way I know it's there is the whistle from the bypass vale at 2000 RPM. Drivability is absolutely stock-feeling. While the off-idle torque of a KB would be a lot of fun, I can also appreciate the smooth power delivery of the centrifugal as the revs build (which is less apt to break things).How do you like the Vortech V3?
how you got builds like this and only put up 4 posts in 10 years?If you are looking to make over 600 RWHP, You are going to spend alot of money to do it the right way or you will be plaing a game I like to call "Find The Weakest Link" for years to come.
You could also put a basic Procharger or Vortech kit on it and have fun.
Going where you are talking about going will require. How do I know, benn there done that got all the tee shirts and spend a shitload of money figureing it all out.
Upgraded block: - Go with 4.125 bore to unshroud the valves. 4.125 x 3.25 will give you big bore 347.
Upgraded forged / balanced rotating assembly
Pistons, pins, Rings
ARP Studs & Bolts
Heads Cam, Lifters, valvetrain, Etc
Intake to support your power level.
Rear control arms, front and rear adjustible shocks, chassis stiffening and integrated sub frames.
Fuel System, Pumps, Lines Injectors, Regulator, Reails, Etc
If it is a 5 speed, you will need, trans, clutch, flywheel, driveshaft
Gears, Axles, Wheels Tires, Etc.
The problem with building up a 95 GT or Cobra, is these cars were designed to support 250 flywheel horsepower, when you put 600+ rear wheel horsepower, things break and as you fix each, the next thing down the line breaks - Hence the "Find The Weakest Link Game"
My first build was 650 RWHP, ran that Street Strip for 3 Years and learned alot of lessions, the second build was 800RWHP also street and strip.
A Few Pic of the second build.
View attachment 13890View attachment 13891View attachment 13893View attachment 13894View attachment 13895View attachment 13896View attachment 13897View attachment 13898 View attachment 13899View attachment 13892
Oh yeah I know it'll be a lot of money and a lot of work I just wasn't sure what compression ratio worked best with these cars that's all. Like when I built my jetta it really liked 8.5:1 compression ratio to make around 450 whp sadly didn't finish that build but here I am now with my mustang and I couldn't be happierIf you are looking to make over 600 RWHP, You are going to spend alot of money to do it the right way or you will be plaing a game I like to call "Find The Weakest Link" for years to come.
ARP Studs & Bolts
