supercharger yes or no?
YellowGT5.0
I have a 94 Gt with the following mods
-306
-forged pistons
-e303 cam
-ported gt 40 iron heads
-1.7 rr
-Ported cobra intake
-BBk CAI, shorties, 65mm tb
-24lb injectors/Maf
the compression is around 9.5:1, i still need to check exactly
After building this setup i've been driving it for a good year and want more power.
with the compression being kinda high i dont know if putting a S/C on it would create problems.
What do you guys think?
5.0kid
I say yes, that compression isn't too much higher than stock and they run s/c on stock engines all the time. You may have to run a little lower boost, but shouldn't be too bad. You could also call the company you are thinking of getting the s/c from and ask them what they recommend. I would also recommend a tune once you get the s/c on it to make sure everything's in check.
LAFENATU
You'll be fine. Final compression with the GT40's will lower the compression most likely. GT40 heads are 65.5cc
As long as there is no blow-by etc.
I would put a blower on a 10:1 motor. Just gotta be careful...that's all.
.02
Inspector13
I'd say yes.
9.5:1 isn't too high. Probably only be able to run about 8lbs of boost. If you do it I'd suggest bigger injectors and a tune.
spdtrip
I think it would be fine also, I know it's a different motor but I know a lot of 99-01 cobra guys running
8-10-even 12# on pump gas race on 12# and I believe theirs is 9.8:1 stock.
