supercharger?
staind reality
Another qu :thumbsup:estion! Motor has 150 plus and plans to put new in eventually but would a supercharged hurt it with these miles and suggestions on what kind to get or if worth it and if can be moved to new motor eventually is greatly appreciated. Would like around 400 HP n trq. Motor is mostly stock now. Underdruve pulleys is about it
LAFENATU
As long as the motor is making decent compression it'll be fine.
I recommend a Vortech V3 Si trim. If you can find a vortech S trim that would be fine too. As far as making 400 with stock heads, let alone a stock long block it's not gonna happen but you can probably make 325 or so.
The supercharger will be able to swap to another 302 based engine without problem.
