danielson631
- Joined
- Jun 1, 2009
- Messages
- 802
- Reaction score
- 3
when i punch it in first gear at no matter what rpm, once it gets to about 4000+ it will sometimes surge and loose power, and the low coolant light will kind of become dull and then brighten up until i let off the throttle or shift into second. while in second, around 5-6k it happens again.
only mods are in my sig
i did some work where i had to drain the coolant, I THINK I MIGHT HAVE AN AIR BUBBLE. when i check the level its normal.
heres my problem, my coolant crossover cap is like SIEZED shut, stripped and chewed up from trying to remove it, drilled out/ extractors didnt work.
idk what more to do but take it to a shop and have them try to remove it ( i have another cap) or just buy a new crossover tube somewhere...
until i get it off, i cant burp the system :dontknow:
is this why my car is surging at high RPMs?
one more thing, usually when i had even the smallest air bubble in the system, it would constantly overheat. i have not had ONE problem of it overheating since a month ago when i drained the coolant.
