Sway Bar Mount bolts broke
dale1bre
Springfield, MO
inside the frame. Anyone have solution for this? Was thinkin of just cutting them off, and then drilling holes through the top of the frame, and just getting longer bolts, but I am open to any suggestions!!!!!!!!
Warhorse Racing
Here's a photo of an OEM sway bar bracket and the hardware from my 2000 GT. You can see that the bolts are designed to attach to the frame like a speed nut. If you can get the brackets off, you should be able to remove what's left. MPS Auto Salvage might be able to sell you OEM bolts. The aftermarket aluminum sway bar brackets I've used come with carriage bolts that slide into the slot in the frame rail, but I can't be sure that hardware will work with OEM sway bar brackets.
