Thermostat or no Thermostat???
New 5.0
I have a 95GT and live in Miami. A lot of people tell me that i should remove my Thermostat. Anyone with experience with this would be a big help. I just replaced my radiator and water pump. The car is a lot cooler then before but while driving in the city it tends to reach the (A) In Normal..Is That normal??
95-stang
No thermostat is not good, the car will not run normally and the ecu will not respond accordingly.
You can fit a 180 stat which is what most people go for, stock is 190.
Paul
That depends on what climate you live in. I've run cars with no thermostat in Phoenix for years, and they work fine.
95 svt cobra
180* the T stat is there for a reason and there isnt a good reason to delete it
Paul
If there's no thermostat, there's nothing to fail shut and overheat your motor. :)
CC'S95GT
Hampton ,Ga.
running no thermostat could possibley make the car run hotter because the water is not in the rad long enough to cool effectively. your just passing the hot coolant through the rad faster. IMO run the 180
riored96gt
SoCal 909
The T-stat also provides a restriction to maintain pressure in the system. Without it, there can be hot spots in the heads and ruin them (warp). Engine builders (Falconer, Loyning, Ivey, etc.) will use a blank gasket with a small (+3/8") hole in it.
I use a Fail-Safe 180...it fails in the open position. :thumb:
N
New 5.0
I have a 180, just wasnt sure if what was on the gauge was normal.
Thanks Guys.
RJayLo
wow I put in a 180 tstat and my needle still hits the A in NORMAL on occasion :crazy2:
It hasn't been very hot here this year, plus I haven't been sitting in much traffic. Also when I got my tune the tuner set the fans to come on sooner to help keep it running cool while idling.
