This should be fun…
C
Cochise
Well... wouldn't be a project without some snags.
Installed the MM K-member and after the painstaking process of getting it all squared up, I noticed the motor mounts are not sitting flush. If you notice in the pictures, the bolt is through, but the tab (that sits in the square, is not.
I thought I could fix it by simply lowering the engine support bar, but when I went to go lower it the chains had ZERO tension on the already. Not quite sure what to do now. Any guidance is appreciated.
I would have fiddled with it more but family calls and I have to work early tomorrow. Hints, tips, tricks welcome.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Put a prybar in there and see if you can wiggle the engine side to side to make it sit down all the way.
