Time for new u-joints
joemomma
I think I'm due for new u-joints - getting a clunk when taking off most of the time. Are there two u-joints on our cars (one on each end of the driveshaft)? How difficult is the replacement?
Staff member
Yes, one at the trans, one at the diff. If you have the stock steel driveshaft, it’s not hard to swap them. You just have to rent a ball joint press (heavy duty c-clamp style tool) and press them out. If the driveshaft is aluminum, I highly recommend taking it to a driveline shop and getting them done. It’s really easy to bend the ears on an aluminum shaft.
badass98svt
Make sure it's not an engine mount, or control arm bushing or something. Get under the car and check the u joints. You'll know if something is bad. You definitely don't want to lose a u joint going down the highway.
PinkieT
Cleveland
If you get real lucky like I did, you will have a crack in your differential. :eek:
joemomma
joemomma
Hope not...I've got a laundry list of things that need to be done to the car, and repairing/replacing the diff isn't one of them.
badass98svt
Mine exploded all over the Cobra behind me on the way to a car show :(. My buddy was not amused.
Definitely was not expected.
