tire tread wear issue
nitto389703
Las Vegas, nevada
first off i have this tire on my front left over a month i start to see excessive tire wear from the edge of the tire tire pressure was set to 35 psi.
so i decided to move it to rear to see if i had a balljoint or front end alignment issue, but no luck tire wore out as fast as it was in the front.
so im lost all the other tires have even wear i leaning toward a bad tire a.t.m. so i put the spare on full size spare rocks :smiley:
[/IMG]
[/IMG] ^ this is how it sits on the car the edges dont touch the road weird??
[/IMG]
[/IMG] ^ this is the spare
all inputs and comments are welcome thank you :thumbsup:
RichV
CO
Probably tire.
35 seems a little low, is that factory? or tire recommended spec?
Addermk2
35 is not low it all for our cars. it's actually slightly over inflated. you, unfortunately, have a bad tire.
RichV
CO
I'm thinking of my truck, it's around 60. But yea, the Mustangs should be 30ish. But I would imagine tire manufacturers would have different spec based on compound and size.
blackpony
Yeah I would say its a bad tire. I typically run my tires around 45 lbs at each corner for daily use and lower it when I'm at the track. I don't use oem ford air spec, I run the tire mfg recommended pressure for daily use as it will net better fuel economy.
