tranny issue
x182dan
I would call this a minor issue but an issue thats bugging me somewhat. Every so often it will stick in 2nd gear when I try to shift it. Its only happened a handful of times. It seems like its always done it when the car is cold. The fluid should be full. There is a slight leak at the vss but I just put a clutch in it a couple months ago and the leak isn't that bad so it shouldn't be low and I put fresh ATF in there when I did the tranny. There isn't a bang or anything. It just kinda hangs up in 2nd a little bit when I try and shift to third. Its not hard to take it out of gear or anything it just kinda makes a little pop noise when it comes out of gear in 2nd. It almost acts like I am not pushing in the clutch when I'm taking it out of gear. There is no issues with grinding on any gear and the tranny seems otherwise good. This is a stock t5 with around 115kish. Should I be worried or just live with it doing this once in while?
Thanks Dan
