Tranny question
boosted347
I have just put a fox body tranny in my 94 gt I used the fox body bellhousing and a 5/8" driveshaft spacer from UPR. Now my question is my crossmember did not line up to the tranny right do I need a fox body crossmember? It is the only thing that is giving me trouble is there any difference in the two? Any help appriciated
mich_666
ive taken a few out, and i dont recall them being different, or at least not by alot. is it the middle section that doesnt line up? pretty sure theyre the same.... :-\
militarygt
input shaft on the fox is shorter. you're gonna have some more issues than just the crossmember not lining up.
Schiffy
Norfolk, Va
I agree... I have a T5 out of a '95 GT for sell :)
B
boosted347
everything is fine ecept the slots in the crossmember dont line up with the tranny mount.The tranny is to far forward to line up with the crossmember anyone run into this problem?
ryclef331
Read the WHOLE post. He swapped the bellhousing and fork to put the tranny where it needs to be...so NOW his only problem is the crossmember.
The crossmember SHOULD still line up. I'm not under my car right now but if you're having trouble, you might be able to flip it or slot the holes. You've got everything else covered...
B
boosted347
thanks again ryclef331 I tried to flip around but came out the same I even took my energy suspension mout off and put the stock one back on same outcome I am confused. ???
LAFENATU
So just do what you do in a Fox body when swapping a T5 for a Tremec 3550/TKO setup.
You have to undo the crossmember and slide it forward/backward.
stang4u2nv
why did you use the fox housing for? use your own housing and it should all fall into place. except for the output shaft that is shorter but other than that is all the same and since you got the spacer you will be set.
B
boosted347
Because the input shaft is whats shorter not the output and if I used my bellhousing it would not properley seet in the crank.
