So about a month or so ago my t-5 started grinding third gear so i pulled it out and took it to a local transmission shop. They rebuilt it and i got everthing bolted back up no worries. about two weeks later my trans started leaking. After dealing with it for a little (and waiting for a cruise to pass ;]) i pulled it and took it back over there. They told me the input shaft was too short and because of it being short the throw out bearing? would cause the input shaft to shake and therefore breaking the seal. So they put the "correct" input shaft in it which was about 1/4" longer and now my trans wont go back in. Coincidentally its about 1/4" from the bellhousing but its connected to the clutch splines because when you put it in gear and manually turn the crank the output shaft turns. Could it be that i have the wrong bellhousing? The part number off of it is RF-F4ZR-6394-CA. Any help would be greatly appreciated! Thanks in advance!
