trick flow heads
seth_96_gt
Hey just wondering if anyone on here is running the trick flow pi heads and how they like em and how they flow in comparison to stock pi.I'm looking at a pair but want others input before I spend 2k
JerZeyStangz
Northern NJ
Well there just Trick flow 2v heads for any year ranging 96-04, only difference is what type of compression you want. I'm looking into getting a pair in the future as well. Well if you can find ported PI heads for less, I would go that route, but the pros to the cylinder head is that you can run an aggressive cam etc.
duff daddy
Not true at all, Trick flow heads have the intake valve in a different side of he combustion chamber,they flow better then pi unported to unported and ported to ported. Trickflow head are good, some people make good power. I had a very good fried run 9.46's several times with a 2v and a ysi @ 28#'s. They flow well but to fork out that much money for the heads, if you already have the pi heads..... To me it wasn't justified.
seth_96_gt
Well. I have a 00 pi motor swapped in my 96. With full bolt ons I'm just wonderin what kind of numbers. Anyones been able to pull out of em and how. Well of a combo a kb would mesh up
duff daddy
cams, ported heads and a stock intake manifold, i made 3 to the wheels and made multipul 12.6 passes on a drivetrain (including rear end axles trans and CLUTCH ) with 130k.
JDwhite98gt
Duff, how much power would someone running your exact combo but with TF's unported castings make over your ported PI's?
duff daddy
my old set up??? (comp 270's) ah prob maybe another 10-15 hp??? The set up im building now... maybe more then that. I havent see a whole lot of flow numbers from Trickflow heads at 8,000 Rpm so its hard to tell.
eric
i made 390 on 10#'s of boost from an s trim and a auto. I have been having an issue with the mondo by pass but once i get the boost issue figured out it should be closer to high 400's possibly 500 rwhp
eric
some of the stick cars that i have seen have been making 550 range on 15 lbs of boost, i also heard of a 02 that made 425 on a high compression set up with a carb....
duff daddy
some consider high compression 11.5:1 ..... i have 13:1 and alot of good fridns are in the 15.5:1 .... i guess its all in what is "high" to you
eric
I believe he was running in the mid 13's for his comppression, what kind of octane are you running with that compression?
Stang Lover
Will TF heads unportted / comp 270 or 278 cam / intake plenum TB / full exhaust LT's put me at around 315HP and be boost friendly?
eric
depends on the head's combustion chamber and the piston's dish size, 44cc then i think yes if you're running stock compression, but if you run 38cc the chances of detonation is greater so you would have run a low boost setting or use high octane fuel with more boost..
duff daddy
Either C10 or q16 from VP also working on a Sponsorship with Sunoco for some 260GTplus (104 Octane)
as stated figure out your compression ratio and that will determine what you need for an octane and if it will be sustainable in a boosted applicaton.
McCloud
Johnson City, TN
323 2V 9.0:1 c/r with 44cc TF heads/CMS Stg 3 Turbo cams through a stalled automatic. Should make some good power once it gets some boost.
