Tune Up?
raginglunatic77
I recently bought a 96 GT and I am planning on doing a full tune up to make sure that the it is running at its best before I begin to mod it. I'm thinking oil change, oil filter, and new plugs for sure but any other suggestions as far as new fuel filter, flushing out the trans fluid or rear end fluid or coolant. Also I saw some ad on TV that was some sort of additive to help repair any wear on the cylinder and increase compression if it is leaking idk if this is real or worth it if you know anything about it or what its called that would be great. There is a tiny leak in the rear end but its really minor so if that makes a difference. Also the car has 123,000 and I have no record of maintenance.
Thanks any input is appreciated.
AaRoN
King Post Whore
Cleaning out the throttle body is always good to do with filter or fluid changes.
Cleaning the maf will help restore some lost power as well as other things.
Get that rearend sealed up.
Seafoam ;D
Paul
Plugs
Wires
Oil/Filter
Fuel Filter
Air Filter
PCV
Tranny Fluid
Diff Fluid (unless you're getting gears, just wait till then)
Bleed Brakes
Check TPS
Check Fuel Pressure
CAREFULLY clean MAF
...is a good place to start.
Paul.
griffin7t1
Paul said:
Plugs
Wires
Oil/Filter
Fuel Filter
Air Filter
PCV
Tranny Fluid
Bleed Brakes
Check TPS
Check Fuel Pressure
CAREFULLY clean MAF
Paul.
howw exactally do you clean the MAF?
voidfinger
there is a sticky on it.
Now what i'm wanting to know is how you check the tps. and also the fuel pressure on this durned 98.
