Tuning my 95 GT - What to get and what to expect?
watteee
Sweden
Hello guys!
Im currently working on my 95 GT automatic, and im going to upgrade my engine to get some more power.
Been reading some threads, but i cant really find a common setup. Everyone seems to run different things!
My stang currently has a CAI, and 4.10 gears.
What should i go for next? Heads? Throttle body, intake, camshaft? My budget is about 4 grand.
What do you recommend? And what model / make?
watteee
watteee
Sweden
The engine is out of the car now, and i will strip it down next week to get it cleaned up, and repaint it.
Been thinking a lot on what to do, and what not to do.
I cant get a supercharger, since i live in a country where they wont allow me to run one (And it wont fit in my car either, since its not a 95 Mustang, i just got the 95 GT 5.0 Engine in a old Mustang).
So ive been looking a lot at the Trick flow top end kit.
Anyone got one? Is it any good?
And besides the Trick flow kit, what more do i need?
I got myself a SCT Chip last week from my local tuner (He will tune it on a dyno when im done)
New Ford Racing cables, spark plugs, dist cap and rotor, ignition coil and fuel filter.
Im guessing that i need a new fuel pump? Injectors? Headers? Throttlebody?
How will it work with the automatic transmission? Do i need to upgrade it with a shift kit? Will it stall on low rpms (new tourqe converter?)
This is my first fuel injected V8, so have patience with me =)
T-5 Killer
Albuquerque, NM
Where do you live that S/Cs are not allowed? back on topic I havent had 1st hand experence with the TF kit BUT I know people who have and have had great results.
I would also get a new Fuel pump, Injectors Headers and T/B if the money permits.
Also a new Torque converter would help alot in your performance.
watteee
watteee
Sweden
I live in Sweden (Superchargers are allowed, but not on vehicles that wasn't equipped with one from factory).
How big injectors should i aim for? Fuel pump (is 190LPH enough?).
Is the stock MAF good for tuned engines? Or do i need a "calibrated" one?
Been looking around for a torque converter, but i dont seem to find any for the 95 automatic?
watteee
watteee
Sweden
Hello Guys!
Been reading up some more, and I have decided for a setup now. Anyone running something similar? Should I change something?
Rear end: 4.10 gears and carbon discs.
Gearbox: automatic gearbox (stock - new oil and filter)
Chassis: modified (the driveline is not sitting in a sn95, I've put it on my 1967 FB)
Engine:
Cold air intake (home made, 80mm tubing with K/N air filter)
Calibrated mass air flow meter (BBK 24LB 76mm housing)
75mm throttle bodie (BBK)
Trick flow twisted wedge top end kit (350hp kit)
3/8 intake spacer and SN95 elbow (Trick flow)
24lb injectors (Accel EV1 style)
Ceramic coated headers (BBK shortys)
Catted x-pipe (BBK)
Flow master mufflers to side pipes (2.5")
190LPH in tank fuel pump (Edelbrock)
Accel EEC-IV super coil
9mm spark plug wires (Ford racing)
New cap and rotor
New 160 degree thermostat
New PCV valve
Sct bank 4 eliminator chip with BAMA tune
Deleted eg
So, any opinions? Will a BAMA tune do, or do you think that I will need a custom tune? Custom tunes are shit expensive over here (around 1000 bucks).
Do I need something more? Will the stock gearbox and stock torque converter do?
Any tips?
I know that I ask a lot, but better asking before than after!
Big thanks in advance, Watteee
watteee
watteee
Sweden
Any good reason for not going with the 160 thermostat?
And about the fuel pump, I already got the edelbrock pump (got it from a friend). Will it feed the engine enough? Or do I need to go bigger?
