Turbo 98 gt???
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
[MENTION=14727]96blak54[/MENTION] will tell you that the npi heads will favor the turbo more so than the pi heads. Im sure he can elaborate a little bit, if he is available.
He will definitely want the pi intake though. Thats a no brainer.
96blak54
Staff member
Lawrenceburg Kentucky
Yes, leaving the npi heads in stock form already favor forced induction. Low valve lift, higher spring rate, open chamber design.
Thomas_W
Capon Bridge, WV
One requirement with the On3 kit. Junk the wastegate and get a Tial, PTE or turbosmart. The On3's have had reports of wastegate failures, if that happens, you engine is toast. The V band clamps are said to suck, so those will need replaced as well. If they only provide hose clamps for the cold side, I would replace those with T bolt clamps as well.
Then dont forget about the other things your gonna need that most kits dont include:
gauges and bezels
fuel pump (255lph should be plenty)
injectors (42/60's)
handheld tuner and dyno tune ($600+)
Stock982v
Houston , Tx
Idk if anyone is still here ,but I honestly lost interest in the car for a while , but I'm saving up for an On3 kit as we speak. Since last time I've posted , I've lowered the car and put on a 281 wing. Thinking about picking up some saleen wheels, but thinking about just skipping that and saving for the turbo kit.
Just curious I mean turbo is fun for sure but was supercharging ever considered? I ask because we all know the issues that can come up withe the on3 kit with fitment and using some cheaper products in the kit and that there are a number of more reliable, easier to install supercharging kits that would do just fine on a street car that occasional goes to the track. No need to swap a K, still great power and basically a bolt on with no issues on fitment or cheap shtuff....
97stanger
Agreed. You can get a centri setup that will be way more reliable, no front suspension upgrades needed, and provide great power. Torque won't be all that impressive but definitely something to consider
evilcw311
Most Evil Member!
Louisville, KY
Stop hating on turbos just cause y'all took the easy way out!!!
