turbo
Bianner
so i wanna turbo charge my gt. what would i have to upgrade to support the added power if i have to. whats the best systems out there that won't put a giant hole in my pocket.
got5.0
Atlantis
just don't use the turbo that is supplied with it, upgrade the turbo itself because I've heard not soo good things about it.
Mustang Mark
+1 get the masterpower turbo upgrade
1996mustangGT
On3Performance makes a great kit.
Stuff you'll need besides the kit:
Tubular K member & Coilover setup
Injectors
New Fuel Pump
New MAF sensor...have to ask on3 which one
Thats the only things I can think of right now. Get in touch with on 3 and they will set you up.
LAFENATU
Injectors
New Fuel Pump
...or you can buy a blower that will make just as much power and has more than enough in it to split that block in half and not need a new K member, coilovers etc.
1996mustangGT
Injectors
New Fuel Pump
I didnt say thats the route I would go nor recomend; He asked what it would take to run a turbo.
94svtturbo
boost brothers turbo kit is what im running. no need for a new k member or anything like that.
Upgrades needed:
Bigger injectors
High flow fuel pump
A new MAF sensor
and a good tune
B
Bianner
LAFENATU
I see, said the blind man :eek:ccasion14:
LAFENATU
Bianner said:
thanks for all the info guys. i couldn't find the boos brothers kit but i came across this and it looks promising sure its not top of the line but i'm trying not to spend too much money.
http://cgi.ebay.com/ebaymotors/94-95-96-97-98-99-00-mustang-v6-v8-t3t4-twin-turbo-kit-_W0QQcmdZViewItemQQhashZitem5888fbf17cQQitemZ380255334780QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_3691wt_1042
Why do you think that kit is only ~$900...it's 110% junk.
If you have your heart set on a turbo kit, I would talk to the dude on here from On3performance. That kit looks like better quality than the boost brothers kit and you have someone to talk to about problems/troubles right here on the board.
Make sure you get your hot side coated or at least covered in something to support high tempatures.
I would also recommend getting a much better quality turbo when you can also.
