umi lower control arms
JDwhite98gt
1.What are your needs/wants for the car?(Strip/street/Corner carver)
2. Is it a daily Driver?
All of that info will give people a better understanding for what is required for your application. I personally have never heard of that company and If I haqvent heard of them then I wouldnt buy parts from them. Yes they are cheap, but that might also be indicative of the quality.
JDwhite98gt
I would go with a more reputable manufacturer like Maximum Motorsports, Steeda, Hotchkis (I have them)...etc. If its just a DD and you want to "Firm" up the rear go with a regular duty, non-adjustable LCA. If you want to change ride height in the rear you can get the ones with an adjustable spring perch. The more commonly used LCA is one from Maximum Motorsports with adjustable spring perch, Poly bushing on the axle side and Heim joint on the chassis side. Check out Maximummotorsports.com
ZFan88
^^ Yup...I have the ride-height adjustable extreme duty lower controls arms from Maximum Motorsports. Not the cheapest, but very good quality and customer service. Install was easy...aside from me having to cut the head off of the axle side lca stock bolt.
Z
Zwolaver21
gnx547 said:
I wonder if UMI control arms are made in USA?
I believe they are made in the US.
I will probably end up going with MM but was just wanting to see what people thought of umi first. Thanks for the help.
Pennywise2
I never heard of these control arms.
Get your control arms from a more well known company.
I recommend getting the Steeda or MM control arms.
