The pulley is from a modular steering pump. It will need minimal machine work to adapt. I.D. needs opened up .040" and a little bit off the hub length. Pulley is 5.5" O.D. Original pulley size is 2.5" O.D.
My concern is that even at driving speeds it won’t put out enough to maintain the battery as it’s now spinning at basically half of what it should. It would be like driving around with an alternator that is dying.
It will most definitely:
1) not create enough voltage.
2) run hot cause it’s not spinning fast enough to cool the internals of the alternator
3) burn up the regulator cause it will be overworking to try and make up the difference.
But again, please proceed while we watch and enjoy the popcorn. I’m curious to see how long before it does start causing problems.
"Always with the negative waves Moriarty, always with the negative waves."![]()
#1)Isn't the only load on the alternator whatever the draw from the system is? #2)So trying to slow it down is only going to reduce your ability to charge, and cause issues?#3) I.e. wouldn't shutting electrical devices off reduce alternator load? Seems to me it would be better to reduce weight of extra batteries.
Being a realist doesn’t make me a pessimist.
Scott and I both come from high end mobile electronics backgrounds and we know what problems udp’s normally cause. This behemoth will be even worse. It’s simple mechanics and understanding of such.
Again, I’m curious to see Gary’s results with meters being used to show if it can even keep up with the current drawn during driving. I’m just explaining why it’s unfortunately going to cause problems.
