upgrade of my bullitt
carsten
Germany
Hi,
I live in germany it is not easy to find a dyno here, so what could I do without put the car on the dyno.
Can you prefer the steeda underdrive pully set or a lightweight flywheel.
I plan to install a new clutch, so what for a clutch and flywheel would you prefer to me for my bonestock engine.
It is a windsor engine with the code X.
many thank´s carsten
Gears would probably make the biggest differance in the way the car feels and pulls.
Headers, high flow cats and better flowing mufflers should give you a few HP.
UDP's might give you a couple HP,
Light weight FW and alumnium drive shaft will lighten the rotational mass
Hi,
considering how hard parts are to get over there, I'd suggest the under drive pulleys. That way if you have any issues you can simply remove them. :)
I suggest getting your OEM flywheel resurfaced and backing up with an OEM clutch. If you want a little extra "oomph" track down a king cobra clutch in case you want to add some power down the line.
C
carsten
Germany
It is really bad that no one here in germany has parts for my car, no problem to get parts for an 05-11 mustang, but parts for an sn95...no chance:(
I have a friend in Austria with a wicked mopar with the same problem. When he finds things that he can't get there he has them shipped to my house and then I ship them to him, in fact a programmer showed up on my door this week he told me to hold onto till he got a couple of other things. Happy to help you out if you find a part here you need.
As for pullies I am not big on them if you do much city driving. You will find your voltage low at lights/idling and after some time it can cause damage to your alt. If your on the highway a lot them sure, not a problem.
C
carsten
Germany
Thank´s a lot for that, I will send you a message if there is something I need:thumbsup:
Only part I/you have to work around is that I am disabled because of some digestive issues. Sometimes it can take me a week to get it back out just because I don't get out a lot but it will get out.
Jerry santos
