Upgrade to.. PBR Dual Piston Front Brake Calipers
divco13
First I want thank you accepting me to this forum.
I have a question for those here that experience with, mustang brakes.
I have a vehicle that has front 2.9 dia piston calipers. ( GM ) I'm am looking at a pair of Dual piston 1.7 pistons. ( PBR Dual Piston Front Brake Calipers & Brake Lines 94-04 Ford Mustang )
Looking to lower the volume of fluid used pressure the calipers, in order to reduce pedal travel.
Increasing the pedal pressure will not be a problem as the pedal length length is adjustable/
How well do these work using the 11" x 1.4 rotors ? " 11" rotors are what is needed to fit in 15" wheels "
Fabrication new brackets is no problem.
94-04 Ford Mustang
Thank you for any opinions , I appreciate the help.
Bob
driftin
Work great, you can RR them hard with no fade if you have some cooling ducts. This is the lightest stock Ford system for the size. I run them in the rear also. Lots of pads to try out.
Call here and talk to Dave..
https://www.zeckhausen.com
Great to hear the list of options. We'll working on buddy's '97 Mustang right after we finished installing the headache rack and roll up tonneau on the current truck project.
EdgarR213
Staff online
