upgrade upper control arms?
currently i have a MM panhard bar and a kenny brown shock tower brace installed on the rear. I have MM lower control arms and bilstein shocks with MM coil overs that i'm going to install next week sometime. I was wondering if there is any upgrade i could/should do to the upper control arms. Are the stockers ok? should i replace the rubber bushings with new ones or replace them with something else?
the car is my daily driver
BIGDATOWN
With the majority of MM Panhards setup you remove the upper control arms completly.
BIGDATOWN
You know what, your right, I got them reversed lol But I should also add that MM only prefers the ford heavy duty uppers to allow better articulation with less bind. Or you could always get the aluminum bushings that rotate freely for less bind but much more noise.
