upgrading rods (only) on stock rotating system that has low mileage
JerZeyStangz
Northern NJ
Hey Sn95 brothers,
I always like to ask on unusual questions but is it possible to upgrade only the rods on a stock or modded long block with the stock rotating assembly? Do people even do this if they have a some-what low mileage engine that they want to beef up without going fully forged? What are your thoughts on it?
-Nate
03DSGGT
SN95 Supporting Member
Akron, Ohio
Its definitely doable. Nowadays everybody is running Coyote rods. They are a direct swap and will handle more power and RPM than the stockers. Plus theyre cheap, I paid like $160 for mine from Tousley...
But if youre using stock pistons, the coyote upgrade is kinda overkill. The stock rods are perfect for the stock pistons. Either are time bombs when the power levels are up past 400rwhp.
Each to their own, but if all your upgrading over stock is the rods, then I would not bother.
Now if you were to add a set of forged pistons.....oh baby! She gets the rods!
What has you thinking of just upgrading the rods and not the pistons?
Boss rods are the way to go but if I was going to go through that trouble I would at least find a cheap set of forged pistons. Once you rip it apart you will need to buy some hardware and gaskets so make it worth the time and money when you do it.
whiplash473
Northern IL
I may be missing something but with intending to keep the rest of it stock, why would you upgrade the rods at all? Unless you've upgraded your heads, at which point I'd ask why you didn't do the rods then.
JerZeyStangz
JerZeyStangz
Northern NJ
What made me think up this idea was that since I'm upgrading the top end of the motor, why not throw a set of boss/coyote rods for added insurance. Can you just replace the rods/pistons without rebuilding the block from scratch. I know that the Pistons wear differently in each bore so I don't know how that's going to work out. This why I just thought of upgrading the rods with top end kit because the car is going to be boosted. You know the deal droptop [emoji6]
This all depends on block condition. If the engine was running great before rebuild, yes...a good cylinder honing and clean up would all thats needed assuming purchased pistons and rods measure good.
Ive done a few very successful junkyard builds that are still running strong,.....you couldnt do any worse!
JerZeyStangz
JerZeyStangz
Northern NJ
Instead of doing a complete tear down, would it just be easier to throw in rods? I think I'm going to chance it and just do the top end with very low boost.
The big problem would come in at the fact that to do the rods, you have to remove the oil pan. Its easiest to do that by removing the engine. If you are doing rods then you already have to remove the pistons from the block. At that point, the engine is out of the car, the oil pan is off, the rods and pistons are out, now you are staring at a crankshaft that is begging for new bearings and arp studs. Do you get where im going with this?
Exactly!
And after you break it down and rebuild a lot of the Ford bolts are one time use so you either buy new or go to the ARP stuff which will hit you in the wallet up front. The little things add up quick on the build list.
I would run it with boost as is and throw a few dollars to the side each month saving for the rebuild.
JerZeyStangz
JerZeyStangz
Northern NJ
Absolutely. Just thinking of ways to do this some-what efficiently, but $$$ always plays the biggest factor lol.
Exactly!
This was my plan all a long, this car hobby sucks at time. Thanks Droptop.
whiplash473
Northern IL
Unless there's a problem with an individual cylinder, the pistons shouldn't be much different from one another. The rings and cylinder walls might be a different story, but like @96black54 said - if there's no issues then a simple honing would do fine.
JerZeyStangz
JerZeyStangz
Northern NJ
I know for sure when the engine gets rebuilt for power I will go this route but I was just trying to do cheap insurance for rods. I'm going to just leave it a lone till I can afford a built bottom end.
Willis_98GT
DFW Texas
Glad to see you're finally building her up old friend
I am here to con other people in to tearing their cars down lol. You'll get it, and we will all be there to help.
Willis_98GT
DFW Texas
sn95 brothers for life
We gotch ya back!
Its been 10 years and engine is almost stock. I am wayyyyy over due. Droptop and Lwarrior are encouraging me haha.
Nate
I hear ya man. I'm hopefully ripping mine out in a few months, Wanna buy the entire setup? Damn I wish you lived closer
EdgarR213
