Valve train Noises.. :(
birel21y
Hi guys, so my engine is now running, and running quite well. The only thing that has been bugging me is that I have a bit more valve train noise coming from the valve covers. Its no horrible, but more than i had with my last engine. The sound is even with both sides, and no big tapping, etc. How much noise is acceptable with;
1.7 crane (cobra) RR's
Crane 2040 cam
OE lifters
OE pushrods
95-stang
Some roller rockers can be a lot noisier than stock, depends what your definition of noisy is.
Jrgunn5150
It's probably normal, but you can always pull the valvecovers and check the lash and everything.
B
birel21y
Is this correct??
Jrgunn5150
If it's a solid cam, but as you have a roller tappet hydraulic cam, you need to follow this procedure
1. Remove the valve covers, and pick a cylinder that you are going to set the preload on.
2. Hand rotate the engine in its normal direction of rotation and watch the exhaust valve on that particular cylinder. When the exhaust valve begins to open, stop and adjust that cylinder's intake rocker arm. (Why? Because when the exhaust valve is just beginning to open, the intake lifter will be on the base circle of the lobe, the correct position for adjusting the intake.)
3. Back off the intake rocker arm adjuster and remove any tension from the pushrod. Wait a minute or two for that hydraulic lifter to return to a neutral position. The spring inside the lifter will move the pushrod seat up against the retaining lock if you give it time to do so. (If you are installing brand new lifters they will be in the neutral position when they come in the box.)
4. Now spin the intake pushrod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the pushrod, you are at "Zero Lash". Turn the adjusting nut down one half to one full turn from that point. Lock the adjuster into position. The intake is now adjusted properly.
5. Continue to hand turn the engine, watching that same intake. It will go to full open and then begin to close. When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder. (Again, when we see the intake almost closed, we are sure that exhaust lifter is on the base circle of the lobe.) Loosen the exhaust rocker arm and follow the same procedure described before in steps 3 and 4 to adjust this rocker arm.
6. Both valves on this cylinder are now adjusted, and you can move on to your next cylinder and follow the same procedure again.
