chaseevans72089
I HAVE A 95 GT 5 SPD. I HAVE A VIBRATION THAT I THOUGHT WAS A MISFIRE. BUT CONCLUDED THAT ITS NOT. IT VIBRATES MOST IN 2ND GEAR FROM 1800 TO 2500 RPM AND THEN GOES AWAY. ALSO VIBRATES A LITTLE IN 4TH BUT NOT NEAR AS BAD (BARELY NOTICEABLE). I DID NOTICE THAT THE SHIFTER SHAKES ALSO WHILE THIS IS HAPPENING BUT NOT AS BAD IN 2ND AS IT IS IN FOURTH. DOESNT MAKE MUCH SENSE. A BUDDY OF MINE SAID HE THINKS ITS THE OUTPUT SHAFT BUSHING. I JUST BOUGHT THE CAR A COUPLE WEEKS AGO. IT SAT FOR A COUPLE OF YEARS. THEY COULD NOT GET IT RUNNING AND AFTER THEY THREW A FUEL PUMP AND FILTER AT IT THEY GAVE UP. I BOUGHT IT AND FIXED THE GAS LEAK AROUND THE FILLER NECK GASKET AND FILLED IT UP WITH GAS AND IT RAN FINE. HAD A MISFIRE AND I REPLACED NUMBER 5 INJECTOR AND CLEARED IT UP. RAN CODES AND CYLINDER BALANCE TEST AND ONLY CODE IS 172 CODE. I FIXED ONE VACUME LEAK AND DONT SEE ANYMORE SO IM STILL CHASING THIS LEAN CODE
BUT MY BIGGEST CONCERN IS THE VIBRATION. I ALSO REPLACED THE HARMONIC BALANCER. ANYBODY ELSE KNOW WHAT IT COULD BE?
