Vibration
Late4Work
Well i have a vibration, and i have a sneeky suspicion what it is but just wanna check......ok when im driving and let off the gas my steering wheel doesnt shake, but when i apply the brake it vibrates bad........now i think its either brake shoes or rotors.......opinions??
uncltrvlnmatt
Pa.
Does the brake pedal pulsate? If yes, warped rotor.
Do you hear a grinding noise? If yes, worn brakes + maybe a bad caliper.
Late4Work
Late4Work
^^^lol......i havent noticed a pulsatingness.....but ill check tomorrow on my way to work
I have just the steering wheel too... but my brakes are def shot. The rears one barely hold it with the emergency brake alllll the way up
94 Sn-95GT
If the vibration gets worse when the brakes are pressed Its in the brake system .Pedal usually pulses but I assume its possible for that not to happen.
I had a caliper seize up. Brake started smoking! Hit it with a non contact thermometer 500+* vs about 130 on the other side
