think of it as your spine
It still flexes at it's critical speed. It starts to whip like a jump rope. I used to have a video of mine doing so. I placed a camera under my chassis to record it.keep in mind the ford racing aluminum shaft
is spiraled inside no flex
It still flexes at its critical speed. It starts to whip like a jump rope. I used to have a video of mine doing so. I placed a camera under my chassis to record it.
This has been stated many, many times. The Ford shafts went to crap. I've had two new ones with bent tubing.The one i have is
But mine was built in the 90s shit now not worth a shit
Better quality
I know it isn’t ideal. But I wanted to maintain OEM uppers to avoid binding the rear suspension.Oh great. I hope mine is okay.
By the way, adjusting your pinion angle with the lca's isn't the way to go. Adjusting the lowers changes your wheelbase and if not adjusted evenly; will throw off your thrust angle.
You should measure the drive line angle at the harmonic balancer. How are you measuring the angle at the pinion?
What is the angle of your crankshaft currently?
what’s that tell me?With the vehicle weight on the tires, mark the slip yoke where the tail housing seal lip sits on the yoke. Now unbolt the shaft from the pinion and push the slip yoke as far as it will go into the tail housing. Mark where the seal lip sits on the yoke. What's the distance between the two marks?
