SonicStang said:
KB said:
yes, but your prob not going to need it till you add a power adder. plus your going to run rich and bad gas milage. in my blown 95 i went from 13MPG to 7MPG
??? I thought the comp. manages how much fuel is going to be burned, the rest goes back into the fuel cell (return style fuel system)...
Alright...class in session.
The fuel pressure regulator adjust fuel pressure SOLELY BASED on its vaccum signal. THATS IT. With NO VACCUM (either unhooked OR at WOT), it will allow the max fuel pressure it can (whatever you set it at or factory...depending on regulator used). The pump flows at a constant VOLUME....restricting the flow of the volume increases pressure (this is what the regulator does by opening or closeing the internal orifice of the return port). The computer has NOTHING TO DO with the regulator at all. NOTHING.
The computer controls the timing or and how long the fuel injectors stay open (pulse width). It does this based on reading from the O2s, RPM, IAT, MAF and Throttle Position. All those readings are calculated to figure out how long it should open for.
Now YES, increasing your fuel pressure will fatten up the mix but then the computer CAN reverse that effect by decreasing pulse width....in theory. Its not a perfect world and it doesn't always work that way.
Generally on a stock car by bumping timing and leaning the fuel pressure back a few lbs, you can pick up 5-10hp....plus better economy. What fuel pressure works best varies from car to car. Find what works best for you.
Class dismissed.
