Warped driveshaft concerns.
Bassani50
I'm pretty sure that my driveshaft has become warped, starts vibrating the car pretty good at about 70mph, calms down slightly during acceleration, sometimes during deceleration, as I said, Im pretty damn sure it's the driveshaft, but anyone else have any bits?, the previous owner had "installed" 3.73 gears, Could this also be a concern?, car is TOTALLY smooth till I get into some speed, or basically get the driveshaft spinning at a higher rate of RPM's... Any techs able to confirm my theory?
B
Bassani50
I'm pretty sure it's not a transmission mount, I've made sure to check the hardware and the bolts for looseness, everything is in and tight from replacing my last clutch release bearing
El_Diablo
when was the last time the u-joints were replaced??? no grease-able are stronger and last longer.....
mikey94gt
I would check u joints, then mark the driveshaft upon install. when you still have the vibes, turn it 90* relative to the input flange on the axle, to try and balance the whole thing as an assembly.
B
Bassani50
U joints? really? I thought it could have been the shaft, I'll give it a good gander this weekend at my old man's house, that ****** has a lift I can get it on and really get a look, U Joints... So what am I looking for basically, Bad clips? or worn out bearings under the caps?
CC'S95GT
Hampton ,Ga.
get it on a lift with the wheels unloaded and push up and down and side to side on both ends. i had u-joints going out on my truck and the vibs were so bad, on the hiway i could't see out the rear view.
rgs
i get very bad vibrations at around 85-90 mph. i've replaced the u joints on my car once before... wonder if they would have went again?
CC'S95GT
Hampton ,Ga.
at that those speeds could be tire balance, harmonic balancer, rear end bearings, trans bearings, etc
topless95
You would need to turn it 180 degrees
El_Diablo
if you're going to take the time to take the caps off, spend the money and get two new ones for $35(tops), cheap insurance...
Jrgunn5150
Before I knew how to rebuild transmission and rearends a few years ago, I had a local shop install some 4.10's for me... Had the same problem, bad vibrating at speed, coming up through the shifter.
I goofed around with the exhaust for days (it was also new, thought it might be rubbing) and finally my T45 cracked in half... Rebuilt it, it cracked in half again. Had Promotion build one, cracked in half.
I was moving to California and the second one I rebuilt cracked in half for the FOURTH time in like four months.
I bought a Viper spec T%^, had it shipped to where I was, rented a garage bay, bought a dial indicator and went to swap the 4.10's for 4.30s, and found out the assholes at Akron Horsepower put my rear end together with NO SHIMS!!!
My advice, get it up to speed, get it to do it, and throw the car in neutral, that will narrow it.
427danderson
I had the same problem on my 94 GT. I replaced my driveshaft with the Ford Racing Parts Aluminum one and NO MORE vibrations!! This drive shaft comes with two new U joints as well... I would check those too.. but for the money you can get a new drive shaft, a little more performance (a little), and two u joints... much easier to install too..
Venom351R
Maine
My previous Mustang did the same thing w/ the vibration and it was the U joints. Just bought the Ford Racing Aluminum DS and fixed all of it.
