weird noise after HB replacement [video added]
dutch
Maybe anyone is familiar with this problem...
I had a shop replace my harmonic balancer last friday because it was going bad. Replaced it with a new FRPP piece.
I must say the engine revs smoother and shifter shakes less at idle and highwayspeed, so that's good.
However, since the change, the car has been making a annoyingly loud screaching noise comming from the front of the engine. It only does this the first 15 min of driving and steadily gets more quiet as the car warms up. The sound also gets faster with revs, so it's def something rotating..
Sounds like metal on metal too, not the usual belt squeek some cars have when they're started + my belt is 2 months old..
So I have every reason to believe it's the new HB.. Anyone else experienced this? Should it go away after a few days of driving? Do I need to lube anything?
:dontknow: stupid cars
video added today:
squeeky harmonic balancer
video doesn't do it justice though, it's louder and more high pitched in person..
mikey94gt
Re: weird noise after HB replacement
Maybe the HB is rubbing on the front of the timing chain cover? or the timing marks are bent in slightly. wierd.
it might be a distributor death squeal. start the car and while it's squeeling push a little in the dizzy cap.(front/back/side to side
dutch
dutch
Ill try that thanks!
If its rubbing the timingcover slightly, why would it go away when hot? And would it eventually wear off enough to become quiet again?
Win
Kennesaw, Ga
i agree
dutch
dutch
can't really see if it hits anything, not the timingmarks I think.. maybe the bolt on the waterpump..
Anyway, it's not the disty, I'm sure of that!
mikey94gt
it would go away when hot because metal expands, and the crank will grow some, therefore not rubbing on stuff. I would look for metal shavings. its gotta be something that has to do with the HB, i would think.
dutch
dutch
I'm sure it is the HB.. I'm hoping it will shave off enough so it stops sometime soon..
94 DropTop
or take it back to that shop and have them look at it.
dutch
dutch
If I'm in the neighbourhood I will, but I'm not driving all the way just for that.. thats $80 in gas..
mikey94gt
Oh ya, you guys pay out the A## for fuel over there. I would call them and ask them about it, and see what happens.
5litrarag
what about the idler pulley... those make some pretty weird noises when they start to go bad. Or maybe the distributor as mentioned earlier.
I doubt the HB is touching anything.
dutch
dutch
I've WD40-ied every other pulley and checked the disty.. but it really seems to be comming from near the HB i'm afraid..
94 DropTop
I would call them. Sounds like they messed somthing up. could you try and post a vid of the noise?
dutch
dutch
I'll try tonight
mikey94gt
I wonder if the pulley on the front of the balancer is tight. also, are the timing marks done in silver or white paint?
wierd. Did you see any rub marks on the HB? Is the HB rubbing on the oil pan? It does sound like a pulley though.
mikey94gt
I thought I saw something on the balancer where the timing marks should be, but I figured it was timing marks. it sounds like it is rubbing against a piece of metal that is sticking out like a tab, so maybe the timing marks, or the flange for the front main seal. In fact, does the car make one long squeak after the engine is shut off? I wonder if the front main seal (timing cover to HB seal) is going bad, my car squeaked like that for a while until I replaced that.
94 DropTop
make sure all of your pulleys are tight. thats what it sounded like when my water pump pully came offf on me.
