welds on a cobra
5.0boi
im looking to buy weld wheels draglites 15x3.5 in the front but im worried i wont be able to fit my 13 inch rotors in m my 95 cobra can some one please help me before i buy the wheels and screw myself up
ryclef331
rz5.0 said:
I believe if you do that you will need to switch to gt brakes.
FALSE!
Slap a 3/4" hubcentric spacer on there, might have to shave the cross bar on the caliper a bit BUT they will fit.
thorco3
IN
ryclef331 said:
FALSE!
sounds about right from what I've always heard. A set of longer studs probably wouldn't hurt either, due to the spacer.
joekd
Ct
Longer studs are a mandatory if using a 3/4" spacer, even with my 1/2" spacers there isn't enough threads left to safely hold the wheel on
ryclef331
I hear ya boys BUT I screwed up. I shoulda said LUGcentric spacer. I.E. a spacer that bolts on to the car THEN the wheel to the spacer. OTHERwise, yes, extended wheelstuds ARE a must.
