What 4.6 2v Lash Adjusters is everyone using?
JScams
We are running a 4.6 2v with trick flow heads with 150lb springs,11:8:1 compression, and stage 3 Modular Head Shop cams.
We tried using the Trick Flow lash adjusters and are having issues with them leaking down at higher RPM’s.
I ordered a set of CompCams 84031-16 lash adjusters, but unfortunately they are on a pretty long back order.
I have spent way to much time searching and calling dealers and have had no luck finding them in stock.
What is everyone using for lash adjusters with similar cam/spring combos?
J
JScams
I just picked up a set for my mach engine
Amizon has them pretty reasonable
Evergreen
Are you running a larger cam and higher rate springs? The Comp Cams version have a slower leak down rate.
Running stock springs
I do know amizon has list of the lifters
For the price not bad
I looked around and the prices are crazy
Snorky
I run oem. Ford ones. I just got an order of 20 of them from white bear lakes ford. Unfortunately most dealers wont have them in stock, but the wait time isnt horrible on them.
Ya there is a lot of part shortages going on with ford dealer
And I dont think its because of a pandemic
I believe there stopping the production of gasoline engine parts
Just saying
Oh3GT
what RPM are you turning? and at what RPM are they leaking down at? what are the symptoms' of it? Just curious as i have the same lash adj. from Trick flow but havent had any issues as of yet, but wanted to know what to look for Thanks
