What cams should i get for my NPI heads
sn97gtnyg
what would produce the most power? Im decding to just got Pi intake and new cams rather then full pi swap.
98_MustangGT
im not sure which ones give the most power but im goin with either pi cams or comp cams 262s. i dont know if the 262s fit in npi heads or not though. im sure someone does though.
justinschmidt1
Theres really so many ways to go with it..
but pi intake and some cams will be good...the 262s should give a nice bump up top.
Theres a dude running 13.7s with pi intake and those cams I believe.
Jrgunn5150
Comp 262's won't work without Crower offset retainer's. I think that's beyond what the OP is comfortable with doing at this point in time.
For now, to get your feet wet, get some PI cams, they work with the stocks springs and give you a nice bump. Plus after you get in deep enough to do them and become more confortable with working on the car, then you can do springs', retainer's, and aftermarket cams. The best NPI grinds are Crower stage II's, but they require springs as well.
Pennywise2
If I were you I would just get PI cams instead if you
are really set on getting them.
Stock PI cams and Comp XE262's are just about the
same in specs and the Comp XE262's will only make
alittle more horsepower than stock PI cams.
